Home > Technical > Transfer Box front flange oil
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I have removed my front propshaft and see that there is oil in between the flanges on the transfer box side. Is this normal? It appears to be coming through/past the 4 bolts holding the flange and spraying oil onto the chassis. Looking at some diagrams it appears there is a washer FRC2464, which appears to be felt. Is this a common problem?
Next question, do I have to drain the oil from the transfer case if I'm removing it? I just filled it with new oil, so would prefer not to drain and fill again with new oil?
Thanks
John
Post #1005232 23rd Aug 2023 5:53pm
Dinnu
I believe that later transfer boxes had the output flanges glued to the output shafts, and the glue prevents the oil to migrate along the splines. I used Loctite 648 when I removed my output flange - after cleaning residues of the old glue of course. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005235 23rd Aug 2023 6:38pm
MK
Not sure how common but definitely you need to drain the oil. You will need that felt washer, a seal and a new nut. Before ordering parts I would check the condition of the flange where the seal seats. If just replacing the felt washer, then you could probably get away with the oil inside the box, unless you want to put some sealant. Puma 110" SW
Post #1005236 23rd Aug 2023 6:38pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
There is a felt washer/seal behind the nut and steel washer.
Oil seeps through.
Best (read cheap fix) I can suggest is remove said felt washer, wash in something that will get rid of the oil, let it dry and "pack" the washer with sealant.
Then put it back.
Post #1005237 23rd Aug 2023 6:45pm
John P
Thanks for all the replies. Will be spending this weekend removing the transfer case to replace the output shaft seals, and will replace the washer. Thumbs Up
Post #1005390 25th Aug 2023 8:31am
jfh
You can do it on the vehicle.
Post #1005392 25th Aug 2023 8:48am
Unless you need to do significant further work (such as replacing the bearings) it is a waste of time removing the transfer box from the vehicle, you're creating a huge amount of extra work. Replacing the front flange, oil seal, etc., on the vehicle is a one-hour job. Removing and refitting the transfer box is a full day's work (possibly two if you haven't done it before) and is quite involved, plus there is also the risk of dropping the transfer box on a squashy part of your anatomy.
On the plus side, if you do take the transfer box out you can inspect and grease the output adaptor shaft coupling, and it is not much extra work to remove the gearbox and put a new clutch in while you're at it!
Post #1005394 25th Aug 2023 9:19am
John P
Sorry my answer wasn't that clear. I'm replacing a leaking seal on the output shaft on the gearbox, and will replace the seal on the transfer box side as well. Also inspect the output shaft at the same time. So the transfer box has to come out to do this.
Post #1005397 25th Aug 2023 9:43am
That makes sense! You have no choice but to do the bigger job then.
Beware that removing and refitting the female part of the output adaptor shaft from the back of the gearbox is not particularly easy - the bolt can be hard to remove and the part may need a decent puller to remove it. Also be very careful when refitting not to use the bolt to pull the splined cup back on, it is not unknown for the head to come off the bolt.
Post #1005406 25th Aug 2023 11:05am
