Home > In Car Electronics > USB Charger for a Puma - recommendations please
Paddington
Dear all,
In recent times, I installed a Blue Sea USB charger as part of a double din fascia/ stereo installation on my Td5 (all from Mud). I found the installation easy and I have been very pleased with the results.
I now have a Puma and I want to keep the original fascia in place (with the original stereo) and am looking at installing a USB charger where the cigarette lighter is.
Can anyone recommend a USB socket to go into the cigarette lighter position on a Puma please?
I don't want to rely upon using one of the USB chargers that can be used in a cigarette lighter socket.
Any suggestions gratefully received.
Kind Regards
Neil
Post #1005218 23rd Aug 2023 4:35pm
Mo Murphy
A blue sea double usb from mud uk.
50 Shades of Pennine Grey
Post #1005221 23rd Aug 2023 4:47pm
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi.
Why would you want to lose the cigarette lighter and restrict future options, who knows when you may need that compressor/whatever? And with no easy way to the battery…?
I added a MUD usb into a spare placement in the main dash, plus 2 more.. subtle ones.
One into the MUD glove box, and a further one on the left of the dash on the shelf for passengers to use..
So you really want all those wires hanging around also when driving?
Food for thought..
Ali express also.. cheap as chips for the side 2…
Good luck
https://www.defender2.net/gallery/albums/u..._1635.jpeg Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1005225 23rd Aug 2023 5:13pm
Dinnu
I recently got one of these:
https://www.aliexpress.com/item/1005003406...0PAO82JRZC
Quite happy with it and can keep the original radio. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005231 23rd Aug 2023 5:50pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Just fitted the below to my Puma, looks factory.
https://www.mobilecentre.co.uk/defender-dual-usb-a-c-socket
Post #1005242 23rd Aug 2023 7:37pm
Shafski
I have to admit.. that does look super neat
Thumbs Up Shafski
Post #1005268 24th Aug 2023 6:02am
Oldowner
I have fitted numerous Blue Sea USB sockets to all the Pumas I’ve had, however they don’t fit properly and always need approx 1mm turned off the outer diameter on a lathe to achieve the perfect factory fit in the Puma dash cutout. I can do this for you if you like, it only takes a minute or so on my Myford.
The Mobile Centre one does actually look pretty good, but I’ve had that many Blue sea ones fitted to all the vehicles and also boats I’ve owned in the past ten years I think I’ll stick to them!
Post #1005269 24th Aug 2023 6:07am
Paddington
Dear all,
Thank you for taking the time to reply to my post. It is much appreciated.
Whilst I have undertaken a number of modifications in the past on series vehicles and various Defenders, I am finding the Puma is a slightly different beast and i am keen to learn from the experience of others (as always).
I'll have a ponder on what to do next.
Thanks again.
Kind Regards
Neil
Post #1005327 24th Aug 2023 5:18pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
If you want to charge a newish smartphone then you will want a fast charging usb adapter so check the specifications before you buy.
I fitted one of these to my truck a couple of weeks ago. It supports both of the latest fast charge standards, is also compatible with older usb standards, and with the plastic cap on it blends into the background so doesn't look out of place.
https://www.amazon.co.uk/your-orders/pop?r...B0BHN4HF62 TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #1005377 25th Aug 2023 7:06am
Marks Landy
It’s a bit of a pig to remove the old cigar lighter. Mine really didn’t want to move so things got a little gash…
Post #1005379 25th Aug 2023 7:41am
glpinxit
For the last 2 years I've had one of these via ebay "Baseus 65W Car Charger USB Type-C QC 4.0 Fast Charging Cigaretter Adapter Kit" (item number eBay Item No. 392824357824). Two types uf USB catered for and tells you the battery voltage too. I need to buy another fur the wife's car. It works well. Cheers, Guy.
Post #1018095 11th Dec 2023 7:17pm
