Home > Maintenance & Modifications > Any ideas of stick for arcwelding chassi? |
Defendertomten Member Since: 19 Aug 2020 Location: Avesta Posts: 48 |
Im about to weld the new rear crossmember on . But first i have to repair a bit on the rear last part of the chassi.
What weld sticks type for arc welding (dont really know the english word for it) would be the best? My magwelder is not that functional and out of gas so I have to use the arc welder. Somebody wrote earlier that its 2mm thickness chassi. I have to fabricate the last "c" part i think. Like 20cm in from the rear. What steel type is it? Have not seen that as a repair part for sale. Another question about chassis; I have noticed that aftermarket chassis are not constructed as original with two "c" welded togheter. Just cut plates welded in the corners. Are the strength and the flex the same as original due to the construction? Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
22nd Aug 2023 11:28pm |
Thanks for the answer😁
I have seen some reinforcement in the rear as a half pipe cross the section. I guess i have to remove and reweld it when repairing the chassis end. Are there parts of rear ends for repair available? Half c-sections? Othervise a nearby garage that repairs old cars may fabricate one for me. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
23rd Aug 2023 11:26am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3437 |
Most would fit a crossmenber with either short or long extensions as it makes the replacement much easier. Of course there are also cases where rear most part of the chassis rails are also rotten, so not better alternative.
I only replaced once a rear crossmember (and I hope it will be the last one to), but since it was for a family member, we wanted it to be as good and look as nice as possible. So we ordered only the basic crossmember, https://www.paddockspares.com/kvb000290-td...nised.html . This does not include any extensions. It is also missing the triangular webs that are welded between the top surface of the rear crossmember outrigger and the top of the chassis rail, but were easy enough to fabricate from 2mm galv sheet. The tub had to be removed to reach all weld positions. Some pics after job was almost done. Click image to enlarge Click image to enlarge Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
23rd Aug 2023 11:52am |
Nice😁. I bought all the parts as triangular plates and the small square one as prefabricated. I did not measure for real how far in the end of the crossmember should be though. But its not hard to se the old welds.
The quarter weld on chassie or shorter with flanged extensions that one should stick over and weld seems to be a real moisture trap though. I didnt want that so i went for the crossmember only. And does not look factory style either. I have owned my y2k 130 since 2004 and have no plans to sell it. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
24th Aug 2023 7:57am |
