Home > In Car Electronics > Wiring harness for Alpine ilx705 problem |
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 112 |
Hi
I fitted the ILX-705 recently. I just used the harness that was behind my original single Din pioneer. No problems at all. Problems lie trying to get the into the dash with the miles of cabling. Patience and calmness required.. Try try and try again.. and she will eventually go.. eventually https://www.defender2.net/gallery/albums/u..._1638.jpeg Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
23rd Aug 2023 10:38am |
bluedefender2015 Member Since: 22 Aug 2023 Location: Portsmouth Posts: 2 |
Thanks for that, I managed to get the Connects harness to engage with the original socket in the end, a bit of fiddling with the blades sorted that.
You are right about getting the fascia back on. Just spent an hour fiddling with it and no joy so far. I'll try again another time!! Did you take the metal bracket out before you did yours? Thanks |
30th Aug 2023 5:48pm |
Hi !
Sorry for the late reply.. time runs away.. Yep.. that metal bracket came out.. and then it was still a challenge.. Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
19th Sep 2023 8:18am |
