Home > Maintenance & Modifications > Defender Heated Seat wiring to base only
WPRO18
 2005 Defender 90 Td5 SW Cairns Blue
My original Land Rover heated seat has stopped working, having tried a different seat I've worked out it seems to be the backrest that's no longer working. The base is fine.
So I wonder (in the middle of summer), am I able to just bypass the back support and just connect my base to the seatbox plug. Is that fine / safe to do without ill effect?
I've the wiring / plugs already to do it so its only a few minutes to bypass it.
Post #1004990 21st Aug 2023 2:08pm
landy andy
It is probably a broken wire on the temp sensor at the very base of the seat back heating element. A very easy repair 👍🏻👍🏻
Post #1005051 21st Aug 2023 8:24pm
NickMc
I agree with Andy pretty common and easy enough to unclip the back cover and check.
Post #1005064 21st Aug 2023 9:28pm
