Home > Puma (Tdci) > Clutch pedal stuck to the floor |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Clutch failed on the M1 - waiting to be rescued 😩
18th Aug 2023 12:53pm |
Balls...
18th Aug 2023 1:00pm |
NoLimits Member Since: 29 Dec 2022 Location: Somerset Posts: 58 |
damn, hopefully you are not on one of those bits without a hard shoulder
18th Aug 2023 1:23pm |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 |
Hope you’re ok, just replaced mine with a LOF one and v happy 👍 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
18th Aug 2023 1:37pm |
Anyone know how to diagnose if a hydraulic fluid issue or seals or new clutch needed? |
18th Aug 2023 1:44pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3310 |
I can’t offer any advice but my LOF power spec randomly sticks to the floor every couple of months but you can flip it back up and then it works fine, until the next time! It doesn’t lose any fluid and I’ve bled it countless times with no success. WARNING.
This post may contain sarcasm. |
18th Aug 2023 4:17pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1628 |
The Slave cylinder is inside the box anyway unfortunately. I would make sure they change the spigot bearing on the TDCi they’re a fail point and some don’t bother.
18th Aug 2023 6:38pm |
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 |
I had the same experience on the A1 just after I bought my 110 puma last year. Luckily it was only when I changed down at a turn off. New LOF road spec fitted and it’s been great since. And +1 for changing the bearing. I did that at the same time too.
21st Aug 2023 6:48am |
