Home > Technical > Disable passive immobilizer with Nanocom
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Hi all
I'm trying to disable the passive immobilizer on my Puma 2.4 Defender using the Nanocom, which options should I disable in the AS-10 menu of the Nanocom?
So far, I've tried to disable the following setting:
* Passive immobilize: This settings configures the alarm to automatically activate the immobiliser a certain period of time after the key is removed.
But the immobilizer still starts after a while so there must be more to it...
Note: If this is too sensitive of an information for a public forum, we can use PMs instead Thumbs Up “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1004207 15th Aug 2023 10:49am
