Home > In Car Electronics > Faulty Ignition Switch
Grenadier
Hola one and all, been a while.
I think my ignition switch is on its way out. Every now and then a jump/click before firing, sometimes nothing at all, mostly normal. But what has happened in the last few days is the heater controls/radio/fag lighter not working when the switch is in position two/three. They all work when on, then turn off immediately I go to position three and then on fire-up, allow the key to return to potion two.
I'm hoping that this is just the switch and not the barrel. If this is the case, is it just a straight-up Lucas replacemernt?
Thanks in advance
Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1002170 29th Jul 2023 3:08pm
HardCharger
Sounds like your ignition switch is kaputt. Change out for a new one and all will be well. Happened to me a few times already. Now always have a spare ignition switch handy. A basic precision screwdriver set will also help with removal and installation of the new ignition switch.
As I have ham hands, I remove everything and the key barrel to make things easier on myself. Not too much of a bother really unless you have the break away security bolts then it may be a bit more of a chore.
Post #1002337 31st Jul 2023 2:34am
Grenadier
Thanks hard charger. I noticed on searches that there are two main variants (when ignoring series models and petrol v diesel), a version for a steering wheel lock and one without. Is this a steering wheel lock that is in ADDITION to the standard turn off ignition and wheel locks in place, as per all cars and usual in a Puma, or is it exactly that, the normal wheel lock we all get when turning off the ignition? I can't tell from the images. Monsieur Le Grenadier
Post #1002341 31st Jul 2023 5:22am
Martin
Site Admin
Everything since the 200 Tdi uses the LR039638 switch  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1002357 31st Jul 2023 8:14am
Grenadier
Thanks Martin. Font of knowledge of all things electrical.... Thumbs Up Monsieur Le Grenadier
Post #1002365 31st Jul 2023 9:02am
Grenadier
Martin. Much difference between the Lucas and Britpart versions? Lucas proving very hard to find here in France. Monsieur Le Grenadier
Post #1002367 31st Jul 2023 9:07am
Martin
Site Admin
"Lucas" is just a sticker on pattern parts nowadays - it's banded about as "OEM" but it isn't now, the logo/name have been licenced out.
I think all there is on the market now is pattern (~£10-£15) and genuine (£65).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1002442 31st Jul 2023 5:14pm
Grenadier
Thanks Martin Thumbs Up [/i] Monsieur Le Grenadier
Post #1002635 2nd Aug 2023 4:45am
