Home > Puma (Tdci) > Inj always goin bad when removed
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
This has happened three times.
I do a head gasket change, and when install the original injectors, they spoil. I have tried bleeding them prior to starting, and its the same. For both 2.4 and 2.2. What am I missing? I dont want to keep buyin new injectors everytime I remove the head.
The manual doesnt cover bleeding procedures. But I insure fuel comes out of the supply pipe prior to starting. Then I crank the engine for a fee seconds prior to starting. Can't leave well enough alone
Post #1002162 29th Jul 2023 1:31pm
Dinnu
I read somewhere that you should not bleed fuel from the high pressure injector pipes, like with old diesels. I do not know why and do not know if it is standard practice on common rail diesels. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1002166 29th Jul 2023 1:58pm
