Home > Maintenance & Modifications > Door seals dropping off |
RaenerPuma2007110 Member Since: 13 Jun 2023 Location: Bournemouth Posts: 39 |
What’s the best product to fix door seals in place? Mine keep falling down especially over the doors.
Also what about catering for seals around windscreen, mine look pretty dried out and starting to crack? Thanks |
29th Jul 2023 10:40am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2029 |
To stop the top of the door seal rubbers dropping a few dabs of butyl rubber sealant in the seal groove before pushing it home should hold it in place. As it’s non setting you can still remove door seal if needed. I.e https://www.dortechdirect.co.uk/catalog/pr...gLCDfD_BwE
On the windscreen rubber, and door seal rubbers use Nextzett - Gummi Pflege to keep them in good condition. |
29th Jul 2023 12:48pm |
Thanks !
29th Jul 2023 2:22pm |
