Home > Off Topic > Armoured Cable Advice - routing underground? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1780 |
You should find someone who has or can hire you a hydraulic mole.
HTH Keith |
27th Jul 2023 7:46pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2098 |
It’s difficult for me to picture (without a picture…) but I wouldn’t like to be using that method for that length of run. Apart from the physical aspect, you could also hit/damage other buried services/utilities.
Unless you have access to some specialist boring/drilling equipment, it sounds like a trench may be the only practical option. Others may prove this wrong, and provide you with a more positive response! Good luck 🤞 |
27th Jul 2023 7:47pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 739 |
Rather than trying to go under the tarmac it should be possible to lift a section of brick paving, dig a trench then backfill and re lay the paviors.
We normally lay brick paviors on compacted grit sand over compacted scalpings. The cable trench should be minimum of 450 mm deep and be covered with 100mm sand and electric warning tape before backfilling. |
27th Jul 2023 8:30pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5693 |
I’ve shoved a scaffold pole under a few driveways/roads and use these as a conduit for services. I tend to get the digger driver to force it through.
27th Jul 2023 9:01pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Next time you see a utility company about or installing fibre cable go and offer them some cash to do it
27th Jul 2023 9:44pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17369 |
I've used 3" valve waterpipe (similar to scaffold poles) and driven them under about 20' of tarmac drive, with an accuracy of about 3" at the distant end. I had four or five (I forget) equal lengths of about 5', threaded the ends with the appropriate BSPT thread, obtained suitable threaded connectors, then dug a trench aligned with the intended direction. I made a cutting head using a short length of pipe with one end hammered flat, welded, and ground to a blunt cutting edge, the other threaded, and attached it to the first pipe section. Using a HiLift jack I drove the first section, the added the second and drove that, repeating until the end popped out into a receiving hole I'd dug at the destination. It all worked a treat.
27th Jul 2023 9:57pm |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 411 |
Could you not go above ground around the perimeter on a wall or fence lets say only then going underground when you get to the garden. Or am i missing the point that you need to get to the existing land locked box?
27th Jul 2023 10:08pm |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1037 |
Did think about that but finding someone who has one is slim and imagine hiring one isn't cheap.
Unfortunately, the access hatch, which I think I can get to via an existing conduit and runs from the house to the existing hatch, is in the middle of a tarmac section with no block work. Lifting bricks would have been the easy option. There is no section from the house that doesn't have a decent run of tarmac to cross.
Not a bad shout but I live in a ruralish area, so chances are slim. We're still on crappy connections with no plans for fibre install.
I do think this, and Landy Andy's approach, is probably the easiest and was where my mind was before asking if I was missing anything. I don't have a digger but I think hitting it with a sledge, perseverance and taking my time should get it 12 foot. ...or it could be a total pig of a job
House is marooned on an island of hard landscaping - to get to the garden, I need to cross the island to get power from the house to the garden, across the driveway (tarmac) and brick paving. |
28th Jul 2023 9:14am |
NoLimits Member Since: 29 Dec 2022 Location: Somerset Posts: 58 |
If you live in a rural area go an speak to a local farmer, he will be able to help
28th Jul 2023 9:30am |
Chris S Member Since: 22 May 2023 Location: Aberdeenshire Posts: 43 |
Speedy do the GRUNDOMAT 55MM 14.4KG for under £200 for the weekend I think you require a compressor.
28th Jul 2023 10:22am |
AmL Member Since: 22 Jan 2016 Location: Devon Posts: 30 |
You could use a diamond saw to cut a 20-25mm slot in the tarmac, put the SWA cable in and fill with bitumen. Make it look like an intentional expansion joint. You wouldn’t get anywhere near the ‘code’ depth but at least you’ll know where it is if you need to excavate drive in future.
28th Jul 2023 10:24am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5163 |
Me and my dad have chatted about routing a power to the back garden, where we have our chairs, so we can have some sort of lights and maybe a power outlet or two, Where do you get the armoured cable? my dad was talking about this as we would need to route this behind some trees. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
29th Jul 2023 12:37am |
Any electrical wholesaler, Screwfix, some of the larger DIY chains, Amazon, ebay etc., search SWA cable (steel wire armoured cable)
29th Jul 2023 7:59am |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 193 |
This is how Transco did my water main for me. Yep, Transco lads were working opposite and it cost me four x Chicken Tikka Massala. |
29th Jul 2023 10:21am |
