Home > In Car Electronics > Can anyone identify this purple connector please. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 737 |
I think the "broken" wire from the alarm module will be the antenna.... I have no idea about the purple connector ☺️
24th Jul 2023 8:43pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1623 |
Yeah the one extra loose with the black stuff is for the alarm antenna and has been lengthened to probably tuck in behind the screen pillar trim.
Looks like the other wiring is an add on, aftermarket alarm/locking or windows? I would address the leak you have either at the screen or screen bracket as it’ll wreck your alarm box eventually while you have it off the water staining has begun. |
24th Jul 2023 9:05pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1069 |
If those wires with that extra fuse are green-white and green-red they are the outputs to the hazards/indicators. So, yes, probably an aftermarket alarm connection.
25th Jul 2023 5:34pm |
