Home > Technical > Noisy Td5 Fuel Pump |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 417 |
I have been throguh this sage recently. It could well be the pump but there are two things you can do to check that it is the pump. Get somone to pressure the fuel pressure coming up to the engine - should be around 4bar.
also, check the small 'in-hose' filter gauze as this can block up and cause the pump to make a noise. Defender 130 HCPU TD5 |
24th Jul 2023 6:52am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 625 |
Before starting, voltage for the pump is 12V, after start is a bit over 14V. This means, motor in pump is running faster and noise changes. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
28th Jul 2023 3:35pm |
Mungopark Member Since: 08 May 2017 Location: Wiltshire Posts: 15 |
Thanks everyone, I will look to get a pressure tester on the fuel line and get filters changed as a first step. Currently battling through a catchy harvest so may be a while....
28th Jul 2023 4:53pm |
