Home > Off Topic > analogue electric meters |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5113 |
Only get a smart meter installed if you can get a strong mobile phone signal in your property, as this is how a smart meter sends its data. I say this because I live in a rural area and the phone signal is a bit hit and miss. This has led to a nightmare with BG sending crazy bills. In the end I have had to have the smart meter removed and older meter fitted and lots of phone calls to BG to have my bills re-adjusted. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
14th Jul 2023 2:55pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3384 |
Some do, called a teleswitch. https://www.energynetworks.org/industry-hu...f%20rates. |
14th Jul 2023 3:00pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 |
Thanks CamelMan. Any idea if you can tell if one is fitted?
Gilarion - I have enough trouble with lack of EE signal in the house. I have to sit near a window to be able to make a call! and this is not in a rural area! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
14th Jul 2023 7:05pm |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 |
If you do eventually agree to a smart meter make sure they install one(s) which is SMETS2 compliant. The older SMETS1 standard means that you may need to get the meters swapped out if you change suppliers. SMETS2 uses a national network which all suppliers use.
I'm also resisting the change as Shell are unable to state which standard their meters use. I suspect it's SMETS2 but I want confirmation beforehand. Interestingly, Shell are stating the existing meter (approx 22 years old) is at end of life and "is not reading accurately". When I asked them how they know this they became very vague. I suspect their pushiness is simply to get the numbers of smart meters up so they hit their OFGEN targets. |
14th Jul 2023 7:17pm |
I am pretty sure the chap from SMS PLC said SMETS2.
He also mentioned older meters can become inacurate as they age. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
14th Jul 2023 8:23pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
If you have an Economy 7 tariff it would be a good idea to see if the smart meter offered supports that tariff.
When I enquired it didn't. Just because you're offended doesn't mean you're right. |
14th Jul 2023 8:36pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4733 |
Someone turned up to install a smart meter here (ours is outside) I told him I did not want one. Stuck a notice on the door of the meter to that effect. 1982 88" 2.25 diesel
15th Jul 2023 10:19am |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
If you have a Economy 7 billing then it receives a timing signal via radio. That system is being stopped soon.
Good luck and stay safe, Don Cheers Don. |
20th Jul 2023 10:55am |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3542 |
gilarion, my friend has had exactly the same problem. And electricity meters are in cupboards under the stairs so probably the worst place possible in a house to get a mobile phone signal! My Dad had a smart meter fitted. It was installed by a contractor who installed for various electricity suppliers. The one they fitted him had an O2 sim in it. I enquired about the connectivity problems. It was a couple of years back, but they had an arrangement with O2 that if they couldn't get a satisfactory signal, O2 had (I think eight weeks from memory) a certain amount of time to get it sorted or they were penalised. He said that he had never had many issues, but he didn't live in rural Norfolk and I guarantee he never went anywhere near the north Norfolk Coast |
20th Jul 2023 11:18am |
You are absolutely correct shropshiredefender, most of the suppliers are trying to kill off Economy 7, and they will do it without your knowledge even without a smart meter. I have that bitter experience. I need to read the small print, don't I? Why this is absolute rubbish (from the electricity suppliers) is the whole idea of smart metering is so they can charge different prices for your electricity at different times of the day. This is why smart meters were brought in. It will be a way of smoothing out the max demand. If you are charged a high rate between 5-7pm, a proportion of people will put the tea in the oven (or Air Fryer ) at 8pm, thus reducing the load at the time of peak demand. Obviously if you are rich, just like the London Congestion Charge, you won't give a hoot and carry on as you were. And yes, I know, that is exactly the reason for Economy 7 was introduced We do not have enough electrical supply in this country for our move to electric vehicles and electric heating. We never did, and even with a load of wind farms and a couple of Nuclear Power Stations, we still won't. Only today, one of the large off shore wind farms off the Norfolk Coast has been mothballed as prices have risen 40% and it doesn't make the project cost effective. I wonder if this is a ploy to get more money out of the government as they are desperate for every kW they can get! https://www.edp24.co.uk/news/23667775.vatt...me-halted/ |
20th Jul 2023 11:32am |
Ohhh! Didn't know this! If you rely on electrically heated stored water (an Immersion Heater) this could make an enormous difference to your annual bill! |
20th Jul 2023 11:37am |
