Home > In Car Electronics > Central locking programming? |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
I have a 2002 110 TD5 HT and have had central locking retrofitted.
It works very well except that the central locking seems to activate on a timer and auto locks itself. This happens when the ignition is off and after a couple of minutes it locks up. One of these days I'll leave the keys inside it when it happens which won't be much fun! Does anyone know if it's possible to reconfigure the central locking using a Nanocom? Or does the 10AS need direct programming? TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
10th Jul 2023 8:39am |
When you say retro-fitted do you mean LR retro-fitted or after market stand alone retro-fitted?
If 10As then this may help https://blackbox-solutions.com/help/SM031.html |
10th Jul 2023 8:42am |
It was an aftermarket hardware kit but has all been wired into the 10AS so runs off the main key fob. As far as I can tell the truck thinks it has genuine CL fitted.
It was installed by an excellent auto electrician who knows land rovers backwards, but I've moved away from his area otherwise I'd ask him to look at it. Thanks for the link, I'll take a look.. TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
10th Jul 2023 8:51am |
Ok so it should act like the LR CL then. I think your problem is that "Relock" has been enabled. So yer you need a Nanocom to disable it.
I am a bit far away, but if you are p[assing you are more than welcome to stop in and use my Nanocom to sort this out. |
10th Jul 2023 8:57am |
Many thanks for the offer! I think I know someone locally who has one I can borrow.
Now I know what setting to look for it should be straight forward. Thanks for your help TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
10th Jul 2023 9:11am |
You're welcome.
10th Jul 2023 9:32am |
