Home > Wheels & Tyres (L663) > 20 Steel wheel for defender
DAP2022
Anyone know of a cheap steel wheel to use as spare to help reduce risk of theft
Do any old discovery or RR wheels fit please?
Post #999391 9th Jul 2023 9:52pm
LR Nuts
Disco 3 / 4 the PCD, but LR only made a 19" NOT 20.
VW wheels fit. But T5, T6, were only 18" (even for the Amarok)
All others I can find are alloys.
Post #999397 10th Jul 2023 6:20am
LR Nuts
Just had a second thought. LR 18" wheels are steel white painted.
BUT, LR did an alloy 20" wheel which looks like an 18" steel.
would the thieves know the difference ???
Post #999404 10th Jul 2023 6:48am
DAP2022
I wanted something not worth steeling for parking at airport etc, but in retrospect someone selling 5x 20 defender alloys for £350……
Might just buy 5 😂
Post #999406 10th Jul 2023 7:08am
LR Nuts
yes the PCD is the same 5x120.
But rolling circumference is very different as your road wheels are 20" and white steels are only 18", add the tyre aspect ratio to that and you could be looking at a much smaller overall rolling tyre.
earlier Defender wheels DO NOT fit New Defender.
Post #999407 10th Jul 2023 7:12am
LR Nuts
Here is a list of LR wheels that have a 5 x 120 PCD
You will notice most will be alloys on these vehicles. So to find a 20" steel, is going to be difficult. Mad
Post #999451 10th Jul 2023 11:32am
Retroanaconda
If it’s just for parking then why not just get a cheap set of take-off 18” steels - there are loads available out there?
Contrary to the incorrect information above, all the factory wheel/tyre fitments are interchangeable in terms of rolling circumference so there is no impact on speedo. As the wheels get bigger the tyre profile reduces to match, keeping overall diameter the same.
Post #999460 10th Jul 2023 12:27pm
LR Nuts
"all the factory wheel/tyre fitments are interchangeable in terms of rolling circumference"
But you have to look at all the variables for that to be true.
for instance I have 18" LR Wheels with Pirelli ATs 255.60.R18, where as the white steel wheels are 255.70.R18.
Beware !
Post #999466 10th Jul 2023 12:49pm
Retroanaconda
Which is why I said factory fitments Rolling Eyes
Of course if you fit different size tyres then it will be different. The point is all the factory tyre/wheel size combinations are the same overall diameter for speedo accuracy purposes.
Post #999475 10th Jul 2023 1:10pm
Tim in Scotland
If it’s just the security of the spare wheel you are worried about, I bought a stainless steel, canvass covered 1.2m long motorcycle security chain from Halfords for about £50 for when I park at Airports and city centre hotel car parks. I take it off when I’m at home.
https://www.halfords.com/motoring/motorcyc...59862.html
There is a 1.5m long version which you could rig tightly covering the locking wheelnuts by going twice through the carrier on the back door - the 1200mm long chain is just a bit short to do that.
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #999483 10th Jul 2023 1:31pm
Mudlark
Terrafirma have this at about £90:
I'd be interested to know if anyone has fitted these, and their thoughts, as I need some steel wheels for more serious off-roading.
Post #999495 10th Jul 2023 2:47pm
DrRob
I wonder if those Terrafirma rims will fit over the larger calipers on the D300 etc? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1032421 22nd Apr 2024 4:09pm
Mudlark
I have recently fitted these TerraFirma steel wheels but did need the TerraFirma spacers as well in order to clear the larger calipers on my P400e
Post #1055221 20th Dec 2024 1:53pm
