![]() | Home > V8 > R380 vs lt77 bellhousing |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 ![]() ![]() |
the bell housings are different length between the LT77 and R380 as the rear 5th speed housings are also different, the 380 was made as a direct replacement for the lt77 so the overall lengths with bell housings are the same
the 380 J pinion is the same length as the K/L pinion but the bearing diameter and length differs as the pinion bearing differs Dave |
atakanmerdin Member Since: 15 Dec 2017 Location: Nairobi Posts: 26 ![]() ![]() |
Thanks Dave for the clarity!
