Home > In Car Electronics > Relay
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Relay
2007 2.4 Puma
Is there a separate relay for the rear wiper motor and if so where is it.
Keith
Post #999085 7th Jul 2023 3:31pm
Yes, mounted to the rear door behind the panel, C0124 in the photo below.
Post #999094 7th Jul 2023 5:02pm
keef9t
Thanks, I'll investigate tomorrow
Post #999117 7th Jul 2023 8:25pm
keef9t
Rear wiper not working.
Just an update which may be helpful to others.
Located the relay as per Blackwolf. It wasn't clicking when the rear wiper switch was switched on.
Found a little test in the archives when doing a search (courtesy of Martin). Put a temporary wire from the Green/Black on the relay to known earth and, in my case, it clicked. This wire is a switched earth to the relay.
Traced the fault to broken Green/Black wire in the usual place, inside the rubber sleeve to the back door, where it is constantly being deformed by the opening and closing.
New length of wire soldered/sleeved, all good
Post #999367 9th Jul 2023 6:57pm
