![]() | Home > Tdi > Engine temperature gauge possessed by the devil |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1881 ![]() ![]() |
I’ve had it that the connector onto the sensor has become loose. Have you checked this is OK? If it’s not a good fit it could be on/off and causing the symptoms you describe. I think it’s earthed through the sensor itself (underneath the thermostat housing) so I don’t think a ‘bad earth’ is as likely.
I like old teabags as much as the next guy, but probably expensive to post up here…! ![]() Depending on the connector you could just crimp on a new one to eliminate this potential issue, and if there’s still a problem you’d need to look further. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
I have no direct experience of this, but I am sure I have seen threads about a bad earth on the actual gauge itself, hidden behind the instrument cluster. I can't tell you how to rectify but if you do a search on this or the other forums I am sure you should find one that tells you what to do.
Mossberg is quite correct. The gauges were earthed from the back of their case into the main earthing loom. It will be a small o-ring with a star locking washer. Always worth checking and cleaning the earth connection first.
Don is also correct that an intermittent connection at the sensor could create a wayward gauge needle. I will add that this is a great time to go around all the earth points and clean them up, chassis, bulkhead, the lot. It is amazing how just one bad earth can make things go haywire. In my old TDI a bad earth on my winch, I was advised to earth to the chassis at the time and a dirty earth to the battery created the situation where the winch earthed through the path of least resistance. Unfortunately that was the transmission brake cable and in doing so melted the plastic cable sheath to the cable locking up the brake completely. Soap box time: IMHO the first thing anyone should do after buying a Defender is not to fit accessories, but to clean up all the earths. ![]() |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 324 ![]() ![]() ![]() |
Thanks all, I was hoping I wouldn’t have to remove the dash but looks like it’s going to be on the list. I will update when I get round to doing it, whenever that will be.
