![]() | Home > Tdi > Heater blower fan woes |
If it were me I would stick with full speed. I hardly ever use the 1/2 speed option.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
Rotary knob to the right of the steering wheel. Might have been a hole for a choke on petrol models? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3519 ![]() ![]() ![]() |
You can get a Pulse Width Modulator for less than a Pound. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 ![]() ![]() ![]() |
I was looking at PWM kits on ebay for less than £8. They have an on off switch and the variable speed knob, my concern is the quality and longevity of the componentry as well as where to fit the switch and knob.
I could bypass the included switch by switching the negative via the existing controller (assuming that isn't the prolblem) and then it's just the rotary which could indeed go in the nice spare hole on the steering column. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
There's probably an option E where you buy a, no doubt much cheaper, non-original resistor and repair it that way. You'd have to determine the resistance of the original but I doubt it needs to be too accurate. Darren
That is also an option.
I believe it is 2.5ohms or 3ohms depending on what you read and where. What I'm not so sure about is the power rating that it needs. That said I think there is a guy on Eblag that sells a kit which allows for a "slightly faster" slow setting which wouldn't be a bad option as long as it isn't the switch that is giving me grief. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 530 ![]() ![]() ![]() |
I bought one of the kits off eBay. It's a gold resistor, plus the diagram of how to connect it. All fine although I never use half speed anyway.
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1878 ![]() ![]() |
Well, I'll just put in a good word for the Landreiziger kit.
I fitted one of these several years ago. I'd have to check to be sure but easily 5 or 6 years, and it's been great. I don't know what % of the time it spends on full vs somewhere along the range between there and off but it's just a well made and very functional piece of kit. If you're handy with electronics etc then maybe a DIY alternative makes sense - but if my L'reiziger control failed I'd buy another. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
It would appear that I have a self healing system as slow blow is back this morning. I'm wondering if the boyconfusedbflap open with slow position
![]() Wide Track Sankey- In bits- Gone to a new home M0XQS |
