Home > Technical > Solar to 12v controllers for vehicle use
jst
My solar controller has decided to pack up, well i believe it has.
Indirect sunlight and 2.9v output from a 16.3v input from panels.
Checked it after noticing aux battery was lower after standing for 2 days than expected.
So whats recommended? I need solar in, 12v charge out for 1 aux leisure battery..no other connections needed. 120w solar panel. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #997496 25th Jun 2023 6:57pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
https://uk.renogy.com/renogy-rover-20-amp-...ontroller/
Or you can spend more on higher current models if you’re possibly adding more panels in the future.
Post #997515 26th Jun 2023 4:51am
jst
Cheers Steve, sorted it. Much more efficient with mppt than previous one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #997963 29th Jun 2023 10:52am
SteveG
Glad you’re back up and running (charging) again 😊
Post #997986 29th Jun 2023 6:32pm
