![]() | Home > Technical > Putting plasma rope on winch. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2657 ![]() ![]() ![]() |
I have a Warn 9.5 xp.
The rope is attached, or I should say held in place by a imperial Allen head bolt. I have crimped a battery terminal to the end of the rope, fed it through the front of the winch, under then over the drum. The attachment bolt has copper grease on the threads. I then wind three laps on (ensure that the winch is switched off and the remote away from that one bright spark that say’s ‘what does this button do…..’ Once happy that the first few loops are hand tight and tight against each other, then use the remote to wind the rest in ensure that the rope is neat and tidy and goes back once it gets to each end of the drum. The rope when manually spooling it in isn’t under tension at this point. I you can find a friend, or a tree at the top of an easy slope, wind out the rope again leaving six loops on the drum then winch yourself to the anchor point. Stop with about 1.5m to go, take the weight off the rope then hold the hook with one finger and spool the remainder in. Newer Warn winches use a hole and a dowel to hold the looped end of the winch line to the drum. The idea being is that it will not pull itself out if you spool out without watching the line. For other makes you will have to read the instruction manual. I also use a winch line ‘stop’ device from Red Winch, I can’t remember what’s is called, that locks three wraps against the drum just after the attachment point. This prevents the all rope being pulled off the drum. Hope that helps. |
This will be useful. Good luck |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 ![]() ![]() ![]() |
Thanks guys, helpful as ever. Going to purchase one of those as well.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
Feednin onto the bottom and i tend to splice mine on, dont want it coming off on a lower out! Cheers
