![]() | Home > Tdi > Fuel leak back |
tommac Member Since: 03 Jul 2018 Location: devon Posts: 26 ![]() ![]() ![]() |
Are you able to identify where it’s leaking/dripping from? As you say, the half tank trigger indicates it’s providing some form of vacuum back.
Did the electric pump make a big difference ? |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
I moved the non-return valve forward to the engine bay, not expecting a positive result but as the lift pump has non-return valves there, I thought I had nothing to lose.
Holding tumbs but currently it seems to be working. |
