Home > Wheels & Tyres > commercial tyres
Page 1 of 3 123>
RaenerPuma2007110
United Kingdom 2007 Defender 110 Puma 2.4 CSW Barolo Black
commercial tyres
Just had a puncture fixed and been told my tyres are Van tyres which are harder than normal 4x4 or road tyres and not suitable for my Defender 110 (2007). Apparently they will give a poor ride and potentially stress the suspension. Any views?
Post #996135 13th Jun 2023 3:02pm
JOW240725
Not heard of this before. What tyres are they? Most 4x4 tyres are LT, light truck, but that's normal.
Curious. Confused James
Instagram @suffolk_rovers
Post #996136 13th Jun 2023 3:05pm
Chicken Drumstick
Re: commercial tyres
Stress the suspension.... Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #996154 13th Jun 2023 4:23pm
RaenerPuma2007110
Curious. Confused
Post #996157 13th Jun 2023 4:38pm
RaenerPuma2007110
Post #996158 13th Jun 2023 4:40pm
Use a different tyre fitter in future, this one's trying to con you.
Post #996160 13th Jun 2023 4:44pm
JOW240725
As above! Thumbs Up James
Post #996162 13th Jun 2023 4:49pm
spudfan
Ireland
Land Rover used to fit them as standard in 2008 when we bought our Puma. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #996164 13th Jun 2023 4:57pm
RaenerPuma2007110
Thanks everyone. Thought it sounded fishy.
Now I'm confused about pressure. They were all on 80 PSI !!! when I bought her 2 weeks ago.
The tyres say 83PSI on them, but not sure if that's the max or recommended.
Landrover says 34ish PSI all round
The dodgy Tyre garage told me to put them on 60psi all round.
Post #996165 13th Jun 2023 5:04pm
camelman
Rolling with laughter 80psi !!!
I'd be checking what else the previous owner might have done to the truck!
Post #996167 13th Jun 2023 5:07pm
spudfan
Ireland
If you look on the door post just beside the driver's seat you will see a sticker with the pressures listed. It lists 30psi in front and 48psi in the rear with the maximum amount of passengers. For a full load inside plus a fully loaded trailer the pressure in the rear is given as 65psi.
If you run part load you can reduce the rears which I do to 35 psi and it will give a better ride. 1982 88" 2.25 diesel
Post #996168 13th Jun 2023 5:14pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I remember my 110 was running 30/48psi when I first bought it.
Dropping the rear down to mid 30s made a huge difference to the ride.
Post #996169 13th Jun 2023 5:22pm
spudfan
Ireland
Yep in previous incarnations the 110 had a maximum of 48 psi for towing but I have run the rears at 35 and you do notice it in the ride. If I was towing a heavy trailer I did go back to 48 but it was a rare occurance. 1982 88" 2.25 diesel
Post #996170 13th Jun 2023 5:30pm
RaenerPuma2007110
just found this on the Protyre website:
"Fitting C and LT tyres on cars:
Fitting heavier van tyres on cars and small vans (assuming they fit) definitely isn’t recommended for two reasons.
First of all, C-type tyres may be designed to take a higher load, but they are also designed to travel at lower speeds. Most cars are driven too fast to drive on a C-type tyre, greatly increasing the risk of tyre failure.
Second, C and LT tyres are much heavier. All that extra weight will do nothing good for your engine or fuel efficiency"[/i]
it looks like I have commercial tyres, denoted by the (C), meant for a Van. The tyres have a different construction, hence the higher psi.
not sure what to do now...
Post #996171 13th Jun 2023 5:45pm
camelman
The General tyres you have were standard fitment on most defenders for many years.
Unless they're knackered, there's nothing to worry about.
Post #996172 13th Jun 2023 5:47pm
Page 1 of 3 123>
