![]() | Home > Tdi > 200tdi overheating |
nicholas2012 Member Since: 28 Jun 2012 Location: lanarkshire Posts: 194 ![]() ![]() ![]() |
Hi, everything I was going to suggest I think you've covered simpler things like thermostat radiator etc could be early stages of head gasket or cylinder head problems but if its not pressurizing hoses or losing couldn't is difficult to say for sure, if it is those from my experience it will soon become obvious as isn't a job you'd want to undertake unless sure that's the problem.
Someone else may come along with more helpful suggestions, good luck |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
I’ve know the impeller to become loose on the pump shaft before. That would be my starting place. Then look towards head gasket.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Could be as simple as a loose fan belt. Check to see if there is excess play in it . If it has been changed it is recommended you check it after 1000 miles and readjust if necessary. We have a 1992 200 tdi and I have had it since 1996 and never had problems. 1982 88" 2.25 diesel
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 837 ![]() ![]() |
Is your viscous fan working ?
wrcarter Member Since: 14 Jan 2021 Location: Laois Posts: 45 ![]() ![]() ![]() |
Thanks for the advice lads.
The belt seems tight. There is a small bit of play in it but reasonably tight. It did actually loosen after first fitted but I tightened it up. Viscous appears to be working correctly. The gauge is slightly higher when driving than idling so that would also indicate to me it’s not a viscous issue. Andy, I actually have a spare pump. I accidentally order 2 by mistake and since it was from a UK site, I didn’t bother to return it so it’s the next best thing to try. I have very little service history but it appears to have been maintained reasonably well. The last owner was a mechanic. The engine was fitted in 95 and had done approximately 185k miles since then so probably due a head gasket if not already changed. It’s not showing obvious signs of HG failures but maybe I just need it to get a bit worse. I’m not a fan of the additives to repair head gaskets but would they be of any use here as something to try if it improves things? 1989 Land Rover 110 CSW |
Update time.
I removed the pump and it looks fine other than finding a small bit of blue RTV which some previous mechanic must have used. ![]() Click image to enlarge It’s starting to look more and more like a HG issue ![]() |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 800 ![]() ![]() |
Have you checked the viscous fan is actually working properly? I thought mine was on my 200tdi (it wasn't), I replaced it and it made a vast difference.
A 200tdi should run cool naturally, I have only just taken my radiator muff off from winter and didn't have any problems with the engine getting warm. BORG - Bucks & Oxon 4x4 Response Group ![]() |
It kicks in for the first few minutes. Tested it with a piece of cardboard. Then more or less stops spinning until it’s hot again. Does that sound correct?
Yea, I’ve read that the 200tdi runs cool, hence why I’m concerned that it’s moving up the gauge. It’s not at the red but trying to resolve the issue before it definitely becomes a hg issue. From what I’ve read and my experience with old BMWs is that the viscous is only needed when you don’t have airflow. If you are cruising along at 50 mph, the airflow through the rad should be sufficient. The viscous in my old e30 didn’t work for over a year, just got a bit hot if sitting in traffic but I rarely did that. I’ve never changed a HG before but it doesn’t seem too bad of a job. My worry is if the head is gone, sourcing one in Ireland wouldn’t be that easy unless ye know where there is a good supply of the in the UK that are willing to post and don’t charge a fortune. I have flushed out the rad and engine. A bit of discoloured water out of the rad but nothing of concern. Engine was fairly clean too so I might just reassemble for the moment. I’ve no reason to question the pump now so i’ll reuse that. 1989 Land Rover 110 CSW |
I doubt the fan has been needed for cooling yet this year.
Whip the head off and get a look at the gasket. I’d then suggest you get it to an engineering company and ask if they think a skim is required or not, and if they can cast an eye over it. As you don’t have experience. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1676 ![]() ![]() ![]() |
Is it a proper defender engine or discovery lump? Engine number is stamped front corner of the block flat looking down- drivers side should start 11L or 12L Do not put that additive deleted expletive stuff anywhere near the thing!!!! Any decent motor factor over here can get you a Tdi head gasket next day. Or go to turner engineering and order one. It’s a very simple job on a 200 Tdi. They normally read just over half way when warm, check you haven’t got a duff “new” sensor (I don’t see many now, but recall there was a few different ones?), the wrong temp thermostat for the climate or faulty expansion tank cap |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2694 ![]() ![]() |
How are the fins on the radiator? Not rusted away or clogged with mud/dirt?
Radiator fins are clean, radiator is only 2 years old and not on muddy trials.
The temp sensor was fine initially but potentially could have failed since. It’s a proper defender lump. I am beginning to agree with the above on the HG. I called an engineering shop earlier and they can pressure test and skim for around €180 so it seems to be the way to go. Definitely worth having them look at it while it’s off anyway. I’m quite busy for the next 2 weeks. Wife crashed her car and is using mine so I might reassemble and have it incase over the next 2 weeks and then do the head. I’ll call the motorfactors in the morning and see what they can do on parts. HG gasket and kit. Anything else I need? Any preferred brands or ones to avoid. 1989 Land Rover 110 CSW |
[quote="NickMc"]
Sorry meant to add that that would be my normal response to those things but think I had a moment of stupidity there. Thanks for putting me back on the straight and narrow. 1989 Land Rover 110 CSW |
Intercooler may be blocked. 1982 88" 2.25 diesel
