![]() | Home > Technical > 2008 Puma 2.4 truck cab - Seatbelt buckle compatibility |
Herald Member Since: 08 Feb 2023 Location: Tahiti Posts: 1 ![]() ![]() |
Hi group,
i've two 2008 Puma 2.4L truck cab and the seat belt buckles are stuck on both cars. ![]() i need to replace them and noticed there's 2 different types! The type currently mounted (listed from 2007) is with solid metal L bracket and cost about £60 https://www.defender2.net/gallery/albums/u...om2007.jpg wondering if i can mount the cable type (listed up to 2006) wich costs about £20 https://www.defender2.net/gallery/albums/u...to2006.jpg for the 2 cars this makes about £160 saving i can put somehere else.. ![]() What's your thoughts? any pros or cons to switch between the 2 models? thank you for your feedback. |
