Home > Puma (Tdci) > Remap…should I avoid
Page 2 of 2 <12
bodstruck
If you don't already have one then an IID tool is handy for later Land Rovers. Pete at BAS can load the map for you remotely so you can update the tool via the web and then add the remap yourself. You can then also take it off if the need arises.
Or buy his version of the diagnostics tool. Has a lot of the functions you generally need and will allow you to add and remove the map.
If you are going this route, perhaps also consider having the EGR mapped out at the same time.
Post #995447 7th Jun 2023 2:12pm
Ianh wrote:
Before any map I would suggest upgrading the highly restrictive air intake piping. I.e using the nugget stuff intake upgrade, then look at a BAS intercooler and silicon hose upgrade.
You will notice the engine performance improves with those upgrades alone.
I'd second this. On mine, I sorted out the air intake first, which was effectively like having a mild remap, such was the improvement. I've recently now had mine mapped to 150bhp by BAS and whilst it's very nice, it's not the step change in performance that I've noted when doing similar on earlier vehicles. Darren
Post #995811 10th Jun 2023 8:23am
ATW
Singapore 2014 Defender 110 Puma 2.2 HT Indus Silver
Minch90 wrote:
Another vote for BAS in my 09 2.4, with air box mod and nugget stuff inlet it pulls like a train with an intake growl. Fab stuff
May i ask what air box mod did you do? thanks in advance
Post #997654 27th Jun 2023 2:12am
Jamesgs
England 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
+1 for BAS - I had the remap and intercooler on a 08 plate 145k mile and it has much improved the drive. BAS were also very good to deal with - good advice given.
Post #998510 4th Jul 2023 9:24am
Page 2 of 2 <12
