![]() | Home > Technical > Power steering O rings |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Most decent motor factors would keep a box of o-rings, they are standard metric on the “four” bolt steering box and pennies £
RTC4825 and QYX100280 at box end though are listed |
Tommybahama32 Member Since: 11 Sep 2017 Location: cheshire Posts: 31 ![]() ![]() ![]() |
Thanks for that I will check out those part numbers,
Before you spend your money you could buy the likes of this and probably spend the same or go to a car part shop and get some for about £1 I’m sure Amazon probably do similar.
https://uk.rs-online.com/web/p/seal-o-ring...lsrc=aw.ds |
That's a good bit of kit, I'm a bit remote so by the time I have driven somewhere to find an O ring that kit will have paid for its self, and I've got plenty of spares. Thanks again I appreciate you taking the time to look that up.
