Home > Technical > Red door light stays on sometimes.
AMBxx
This has happened twice so far. I can't find anything in the manual to explain.
The red 'door open' light stays on after closing all the doors and starting the ignition. I first thought I'd left a door open or might have a faulty door switch.
However, if I lock the doors using the keyfob, then open again, the light goes out as it should. No need to touch any of the doors, I just sit in the drivers seat.
Is this a battery warning thing or an alarm warning? If not, what else could it be?
Post #993942 25th May 2023 5:13am
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
What model truck do you have?
I think you're referring to the immobiliser/alarm light, I don't think there is a door open light on the dashboard TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #993945 25th May 2023 6:03am
geobloke
Regardless of model begin by taking a look at the door switches for corrosion.
Post #993952 25th May 2023 7:44am
AMBxx
If it was the door switch, why would locking, then unlocking make the light go out? I don't need to touch any of the doors!
It is the immobiliser/alarm light - it also comes on when doors are open.
It's a 2015 110 XS SW.
Post #993984 25th May 2023 12:28pm
Martin
Site Admin
It'll be the battery in the fob!
A door switch fault would mean the interior lights don't behave.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993990 25th May 2023 1:04pm
AMBxx
Thanks for that. Fortunately, I have the spare keys with me! It first showed when I was in the back of beyond on Hoy. No mobile signal and a long way down a barely used track.
Post #993998 25th May 2023 1:46pm
