Home > Puma (Tdci) > Rear door lock barrel seized
dmtben
Hi all,
I'm having an issue with the rear door (cargo area) lock barrel on my 2008 110 hardtop 2.4 Puma. The lock barrel had been turning smoothly, up until yesterday when the barrel seems to have seized in the vertical position. I've tried copious amounts of WD40 overnight, which doesn't seem to have freed it and also tried some lubricant on the key before putting it into the lock barrel- none of which has had any effect. I can still open the door by climbing into the back through the bulkhead and flicking the switch from the inside, but no luck on the barrel moving.
Anyone got any ideas? Would rather not replace the barrel if I can just grease and fix this one.
Thanks!
Post #993596 22nd May 2023 10:24am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
try some graphite on your key ( use a pencil ) wd40 is not a good idea
Post #993667 22nd May 2023 5:09pm
