Home > Maintenance & Modifications > leak cluch master cylinder |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hi,
I do not use the contact on the master cylinder and it is leaking. Thanks to tel me what kind of plug I can use. Regards Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
15th May 2023 6:58am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3430 |
Are you referring to the thread size of the clutch pressure switch?
According to https://www.lrworkshop.com/parts/SYG500020 it says 3/8-24 UNF. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
15th May 2023 7:58am |
Dinnu,
Thanks for answer. I will try with your information Regards Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
15th May 2023 12:13pm |
