Home > Td5 > Diameter Top Hose - TD5
Mago
Germany
Hi everybody,
I´m thinking about putting a water temperature gauge in my (Disco) TD5.
A good position for placing the sensor seems to be near the "Elbow-Water Out" (ERR7097).
As far as I´ve seen there are two options for mounting the sensor:
The first one is using a very stylish TD5 Coolant Housing by goreproducts (see https://goreproducts.com/products/td5-coolant-housing), the other one would be an inline adapter like this one: https://www.ezt-autoteile.de/zusatzinstrum...arz?c=7542
The "Elbow-Water Out" (ERR7097) is identical in Defender and Discovery TD5, so I think the diameter of the top hoses has to be the same on Defender and Disco TD5 (Disco hose: PEH101080), even if the hose itself is a bit different.
I prefer the inline-solution, it is available in various diameters - does someone know the inner diameter of the top hose in the ellbow connection area??
Thank you Smile
Greetings,
Very Happy Defender 110 TD5
Defender 110 Puma 2.4
Post #992594 14th May 2023 3:03pm
geobloke
The Madman sender is a 38mm ID in-line hose adapter. I have mine sitting between the radiator and left-hand bend in the top hose. It is a good place IMO Thumbs Up
Post #992615 14th May 2023 6:03pm
murph81
Ireland 2007 Defender 110 Td5 PU Belize Green
The inline ones look awful, like a side of the road fix or something.
I would be using the Gore housing if I ws to go down that route.
Post #992625 14th May 2023 7:44pm
Mago
Germany
Perfect, thank you!
Greetings,
Post #992651 14th May 2023 11:02pm
