Home > Technical > 300tdi bent push rod
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
So….. driving down the road and then sudden loss of power, white smoke and sounded like a bag of nails. Pulled over and nothing obvious so got recovered home.
My first thought was head gasket but looking at it in the morning it seemed to be relating to no3 cylinder, lots of diesel in the exhaust. Stripped the rocker cover off and the cone shaped adjuster screw had sheared off on the rocker took the rocker shaft off and the push rod was bent, all others look fine.
As the valve was not operating properly that would seem to account for the symptoms but does anyone have any ideas as to what could have caused just a single push rod to fail and bend?
Thanks
Simon
Post #992469 13th May 2023 10:52am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Snapped timing belt.
Post #993671 22nd May 2023 5:58pm
8619simon
Yes that’s what I thought that first but it was only one push rod and when engine running all other valves were moving fine. It’s a bit of a mystery.
Stripped the head off it this week and the garage reported gasket is fine and no valve to piston contact. Head and block look good.
Post #993681 22nd May 2023 6:36pm
L110CDL
That is good news from the garage Thumbs Up Clayton.
Keeper.
Post #994041 25th May 2023 8:51pm
NickMc
Bad injector leaking
Post #994555 30th May 2023 8:27pm
8619simon
Thank you for the suggestions..... By way of an update... the head went off for a service and valves on N0.3 cylinder were showing some witness marks against the guides and most likely sticking.
New pushrods fitted and new guides and all valves cleaned and ground. Back together and running nicely again so fingers crossed that has it sorted.
Post #994920 2nd Jun 2023 10:08pm
