![]() | Home > Tdi > Defender TDI 200 oil housing filter block to gasket |
You need gasket ERR3607 https://www.lrworkshop.com/parts/ERR3607 - No/12
But if you have some gasket paper you can make one yourself. |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 143 ![]() ![]() ![]() |
Ok, thank you.
But do I need to apply sealant on the gasket? some leaks from that, hoping can solve the leaks issue after change it Thanks ![]() |
Officially... No... But... Some of these gaskets can be quite old stock so might be a little dryad hard. So yes a light smear of gasket sealer RTV is a good idea as it is unlikely you will want to remove the adapter ever again
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3510 ![]() ![]() ![]() |
You do not need to for that application, but very small amount would not hurt. Do not put too much, as it will get into the oil passages, and could block somewhere later on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
alright, thank you so much ![]() ![]() |
Ok Sir, very clear now. thank you ![]() ![]() |
