Home > General & Technical (L663) > Guardian Mode |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1399 |
I only use it in airports. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
9th May 2023 12:44pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2644 |
My wife uses it on her Velar when parked up at work.
Better to have than not. |
9th May 2023 3:03pm |
soundslegal Member Since: 30 Oct 2021 Location: Woking Posts: 101 |
Yes I sometimes need to leave a bike or two in the car at random Travellodges / Premier Inns when travelling to races and use it then in the hope it will result in me being immediately notified if anyone tries anything on (it would take them some time to remove the bike from the car due to dog rack / locks etc!).
9th May 2023 4:18pm |
Badeagle Member Since: 27 Aug 2022 Location: London Posts: 54 |
I use it quite a lot
It’s an extra layer of security Informs you even if someone uses the key I have been called by the security people a couple of times to see if I want it to be tracked when I have used it in Guardian mode MY23 XS 110 D250 2003 Jeep Cherokee Limited |
9th May 2023 6:36pm |
cozz Member Since: 15 May 2013 Location: nottingham Posts: 539 |
I got a call when on a ferry, as landcover thought my defender had possibly been stolen
- guess as it was locked, but moving, but not running was weird. No I know to set it into transport mode when on ferry |
9th May 2023 8:01pm |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 489 |
I use it when leaving for longer periods of time or parking in unfamiliar locations. I have had glitches in the past triggering alarms to my phone - which can be quite disconcerting. But it does add extra peace of mind.
10th May 2023 11:25am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2841 |
l don't seem to have this feature
10th May 2023 12:00pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Do you subscribe to the factory security and tracker system? I have seen elsewhere that if you didn’t then you won’t get Guardian Mode. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
11th May 2023 7:30am |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3407 |
All of mine have had guardian mode, all have had the standard tracker. 24MY 90 D250 HSE, Tasman Blue
11th May 2023 4:35pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Mine had it during the time I had the tracker service active, binned that a while back though.
11th May 2023 5:08pm |
