Purchased for a 110 (CSW or Double Cab), but obviously can be used for a 110 / 90 variant if you don't use the middle row retainers. Also just fine with non carpet examples, smartens / protects the leading edges.
Also includes a pair of Front door entry kick plates.
Brand New unused and still has protective wrapping over everything including additional protection layer on the main face, so remains perfect condition and complete.
-Pair of front retainers
-Pair of middle row retainers
-Final row / rear door retainer
-Pair of front kick plates
-Lucari fixing / hardware / bolts
£No Longer Available plus small bit of postage (happy to send it anywhere) with a next day courier.
Feel free to send over a PM if of interest, or if you have anything to ask etc
Pictures below are from Lucari, but can get photos of my actual items in the clear wrapping prior to purchase if you'd like to see them.
Lucari description:
high quality stainless steel front, middle and rear door carpet retainer plates.
Rear is Direct replacement for original part that often corrodes.
Fronts fit using existing holes and give a superior finish that was never fitted by Land Rover. Come with coach bolts for quality finish.
This set also comes with the two for the middle row 110 Station wagon.
Photo of one in a Defender is just sat in place for the photo. (if it was bolted down it would sit flat.)
This set fits all Defender 110 station wagon, and double cab models.
High quality 304 grade stainless steel foot well a post trims
Very easy to fit just 4 screws
Direct replacement for the painted metal a post trims that are fitted as standard and very often corrode
Laser cut and CNC pressed
These fit all Land Rover Defender 90s and 110s
2nd May 2023 3:35pm
458GT
Updated listing as set will also now included front entry kick plates !
Also includes the fixings/hardware / bolts to install.
Welcome to send over a PM
16th May 2023 4:00pm
458GT
Up we go, happy to consider an offer if it helps
8th Jun 2023 9:41am
CH60DRY
Would take them for £100 if that’s agreeable and if they are still available?
