![]() | Home > Td5 > 90 CSW inward facing seat fixings |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2128 ![]() ![]() ![]() |
Does this help?
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 177 ![]() ![]() ![]() |
Thanks both looks like it uses the bar fixing in the middle then
Edit - this one? ![]() Click image to enlarge Last edited by 2hel on 1st May 2023 2:41pm. Edited 1 time in total |
Apologies if I’m stating the obvious / but you do have the brace between the rear cross member and the seat belt mounting don’t you?
![]() Click image to enlarge You can just make out the aforementioned seat belt bolt installed from above. |
Yes mines got the brace fitted! Maybe I should have looked underneath may have been more self explanatory
Yes correct!!
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
