Home > Maintenance & Modifications > Rover Recaro Vitesse Seats (fitted)
edward
Not sure if these will be as controversial as my grill 😉 but just got my classic Recaros fitted on the passenger side. The bolt pattern is about 2cm off the defender so I had to make a new subframe to fit them to the defender runners. But they work a treat and only cost £260 from eBay …
Ed.
Post #990893 30th Apr 2023 2:37pm
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
Looks good!
What you doing with the old seats 😉
Post #990908 30th Apr 2023 5:33pm
I think it's safe to predict that those won't be as controversial as the grille, they look as though they were intended to be there.
I imagine that access to the lockers is tricky?
Post #990911 30th Apr 2023 6:27pm
edward
Well, yes. But only tricky in that you need to remove the 4 bolts that bolt the runners to the seat box, so less immediate access but time will tell how much of a pain that is in reality.
Ed
Post #990921 30th Apr 2023 8:02pm
edward
Landowner wrote:
Looks good!
Well I’ve only got one in so far … and I had to slightly butcher the frame due to a seized bolt - but if you’re in Lincolnshire you’re welcome to them when I’ve finished.
Post #990924 30th Apr 2023 8:04pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
You seem to be a very nice person who puts the passenger´s convenience above his own! Thumbs Up
Your taste in front grille design on the other hand, well, hmm… Wink
Post #990928 30th Apr 2023 8:26pm
Linds Hanson
You may find leg amputation necessary in order to fit under the steering wheel!
Post #990989 1st May 2023 10:45am
edward
I hope not. Will let you know once the drivers side is in ..- they are pretty much exactly the same height as the standard seats, just wider.
Post #990994 1st May 2023 11:39am
Screbble
They do look like they were meant to be 👍
Great job.
If you put your original grill back on we will all forgive you 🤪
Post #991006 1st May 2023 1:33pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
Where can I see a pic of the grille?! TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #991052 1st May 2023 6:29pm
In the OP's gallery, https://www.defender2.net/gallery/displayi...&pos=5
I think it would be fair to say that it has divided opinion.
Post #991057 1st May 2023 7:00pm
andy2111
LOL each to their own! TD5 hardtop to Puma inspired Poptop - my build thread
Post #991058 1st May 2023 7:02pm
edward
Honestly the grill is good!
But I’ll take the nice comments in the seats.
Post #991077 1st May 2023 8:33pm
