![]() | Home > Td5 > Replacing sliding side windows |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 522 ![]() ![]() ![]() |
I riveted it in, used the gasket you referenced and put some sealant on it too
Shane |
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 177 ![]() ![]() ![]() |
Ah ok brilliant, ill order the gasket anyway then!
be careful when riveting in, you will need someone the opposite side pushing the panel back against you as I was doing it on my own and luckily seen the panel was also moving leaving a gap
