![]() | Home > General & Technical (L663) > Defender hardtop floor catch |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3064 ![]() ![]() |
You need to press down firmly on the top of the release handle with both thumbs, and you'll hear/feel a click as it latches.
lt doesn't need to be locked to keep it shut (once it's latched) but l received two small keys for it with my ignition keys. |
I know nothing Member Since: 15 Apr 2023 Location: Cambridgeshire Posts: 5 ![]() ![]() |
Thanks I’ve tried pressing down firmly still won’t catch perhaps it needs adjusting,found keys in glove box ,can you open rear door from the inside? Seems odd if you can’t
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
There's another thread on the inside boot release. From what I remember, the release switch is tucked away. If not, Powerful UK do a kit.
https://www.defender2.net/forum/topic85737...or+release Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Yes if it's a 90 Commercial the switch is on the side of the plastic trim on the left side. Not visible when looking into the rear of the vehicle
Thanks for photo of door release I've found it cheers
