- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > TD5 exhaust fitting kits |
doruk1981
Dear all,
While the car is on the lift and the exhaust system is off, I decided also to replace the rear and center silencer due the mounts already being corroded and I'm not to keen to have to do this later on ...
With the mounts, I note that there are kits available to keep things easy. However most of them are focused on the 90s. Is there a difference in the hangers and rubber mounts between the 90 and the 110? from LRworkshop I don't see any differences but I can be mistaken. I can order everything individually, but why do the extra legwork if there is a kit ...
https://www.sp-4x4.com/product_p/lrc2337.htm
Thanks as always for the pointers Td5 110 Station
14th Apr 2023 7:13am |
