Home > Td5 > Oil cooler
Jim88er
England 1999 Defender 110 Td5 CSW Alpine White
Oil cooler
Has anyone had bad experiences of the cheap eBay ones? Are they best avoided and getting oem or will they do the job and last a similar amount of time? Thanks.
Post #988852 13th Apr 2023 3:47pm
geobloke
Hello. What oil cooler are you referring to on the TD5 and eBay?
Post #988857 13th Apr 2023 5:10pm
Jim88er
Yeah on the Td5 just below the turbo. I’m referring to the £40 ones on eBay as opposed to the £120 Brit part or £188 on paddocks spares for example
Post #988859 13th Apr 2023 5:22pm
Mdm
well i wouldn't risk my engine on cheap copy parts and not britpart either for that bit....any branded one would work for sure
Post #988874 13th Apr 2023 8:11pm
Bearing in mind Britpart's legendary reputation for quality, I'm staggered you'd even consider a component one-third the price of the Britpart one. I imagine you'd get what you paid for.
Post #988885 13th Apr 2023 10:59pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Oil cooler
I am 5000 km so far on a cheap aliexpress oil cooler, I have another one on stock just in case.
I will like to buy the casing since I have seen it corroded on other TD5s
EDIT:
It has the same Weight (471gr) as the original (469gr) one that was fitted. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #988886 13th Apr 2023 11:07pm
