Home > Technical > diagnosing brake servo
miker916
Scotland 2005 Defender 90 Td5 HT Belize Green
Hi,
The brakes on my 2010 Puma have always been a bit rubbish since i bought it. The rear pads and discs were replaced as they were a bit worn but this made no difference (already had new front discs & pads).
I'm wondering if i have an issue with the brake servo, I tried the usual pump brake pedal 3 times then start engine. The brake pedal doesn't move after the engine has started - that's not normal is it?
Is there anything else i can do to diagnose the servo being at fault?
Mike
Post #988462 10th Apr 2023 10:34am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Pull out the vacuum hose from the servo and check the vacuum pump is working with the engine running (put your thumb over the end and it should get sucked on). If this is ok then put it back in and run the engine for a minute before turning off and pulling the pipe out. The servo should hold vacuum for a while and if you don't get a whoosh/hiss of air rushing in when you pull the pipe then the servo is leaking.
The servos are a bit crap and do split where the master cylinder mounts but the cracks are usually hidden so only really visible when you pull the cylinder away. Just had to replace mine on my old TDI last year after thinking for a year or two previously that the brakes perhaps weren't 100% (still passed MOT though!) and it was much better after the new servo.
Post #988490 10th Apr 2023 2:26pm
miker916
thanks for the help, so it looks like i have some sort of problem but not with the servo:
With the engine running and vacuum hose disconnected from the servo i can feel it sucking when i put my finger over the end.
Connected the hose back to the servo and left the engine running for a minute, switched engine off and pulled the hose out - air came rushing out the servo.
But when i pump the brake pedal and hold it down as far as it'll go then start the engine the pedal dosent move down at all. I tried this about 10 times and it was the same for 9 tries but one try after starting the engine, the pedal did sink.
Post #988493 10th Apr 2023 2:53pm
geobloke
Your brake servo is failing or has failed internally I am afraid. By replacing it you will have your pedal back again.
I have recently been through a similar fault finding experience in Miffy which led to the replacement of the servo.
To give you an idea now Miffy's brakes are good enough to hang you from the seat belts.
Post #988643 11th Apr 2023 6:33pm
miker916
thank you, a new TRW booster is on its way. Fingers crossed it fixes the issue
Post #988773 12th Apr 2023 7:12pm
landy andy
How much is the servo costing?
Is there an uprated option that others have used?
Post #988775 12th Apr 2023 7:22pm
geobloke
There is not really an uprated version. But... there is one that has a slightly bigger internal volume made by County. The housing is more square than the LR item. This is the one that I bought as I was curious that others had said the extra internal volume provided better braking efficiency. I am not sure about that, but thought I would give it a go and Miffy's brakes are superb.
https://www.ebay.co.uk/itm/114248028555?ha...R6bf6O_uYQ
Post #988785 12th Apr 2023 7:42pm
landy andy
Thanks. Notice that is non abs so may give them a call. Just not happy with my brakes, and have swapped most other things. Servo appears ok, but may swap out
Post #988802 12th Apr 2023 9:26pm
geobloke
Hope you get it sorted Thumbs Up
Post #988821 13th Apr 2023 8:49am
Porny
Site Sponsor
£192 + vat inc UK postage for a TRW/OEM ABS spec brake master cylinder
They do fail internally, but most commonly they spit where there master cylinder bolts on (more common on none ABS) IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #989230 17th Apr 2023 12:03pm
miker916
it was the TRW one i went for, only cause autodoc are doing it for 97 + VAT just now
Post #989234 17th Apr 2023 12:20pm
Porny
Site Sponsor
That's cheap! IRB
Post #989236 17th Apr 2023 12:24pm
miker916
it wa the servo, was cracked where the master cylinder bolts to it
Post #996953 20th Jun 2023 2:56pm
I Like Old Skool
I win Thumbs Up
Post #996998 20th Jun 2023 10:46pm
