- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > HELP after Fuel Filter Change and Fuel Regulator over haul.. |
roche1800
HELP after Fuel Filter Change and Fuel Regulator over haul.. | |
Please can you help me fix my problem, the engine turns over and won't fire up!!
Yesterday I removed the fuel pressure regulator unit and replaced various parts and then fitted back on and it started and all work perfectly fine.
Then today I have carried a service, oil change and oil and fuel filter change.
I did not put any fuel into the new fuel filter!
The Defender fired up for approximately 30 seconds and then cut out, I have tried many times to start the engine including pressing the accelerator pedal to make the fuel pump kick in.
I have unscrewed the fuel filter and there is fuel and I have undone the the fuel (exit) pipe on the regulator and fuel is coming out.
Now I am stuck, does anyone have any tips please?????
8th Apr 2023 1:09pm |
roche1800
Strangely and fortunately after sending the initial post it started!!!!
8th Apr 2023 6:01pm |
Ianh
Seems like the air is now purged
8th Apr 2023 6:21pm |
