Puma 2.2 electrical issues.
Hi I’ve just bought my first defender it’s a 13 plate puma 110 xs.
A few issues that i need some help with.
1. Instrument cluster back lights are not working. Ive had a look at the binnacle and can’t see a way to change the bulbs.
2. Rear number plate light is not working, new wipac unit fitted tried reversing the wires to confirm I’ve done it correctly.
3 rear offside side light is not working, brake light works fine.
I’ve just installed wipac leds in the back and noticed the issue when testing them, put the old light back on and still the same problem.
5th Apr 2023 8:14pm
MadTom
Did you check fuses? It looks like one problem and blown fuse for "half" of these small lights."Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
6th Apr 2023 7:42am
Martin Site Admin
Fuse 11 is the common factor in all the above. 1988 90 Td5 NAS soft top
2015 D90 XS SW
