Home > Off Topic > Check Your Nuts!!
markb110
Check Your Nuts!!
I had to share Shocked
Looking at the way the wheels are sticking out, at a guess i would say it was the nuts on the spacer.
Post #987492 31st Mar 2023 8:28pm
landy andy
It’s not the wheel nuts that came loose and let the wheel go. It was failed stub axle or more likely wheel bearing as in the clip you can see the brake disc is still attached to the inside of the wheel. Won’t be helped by those wheels sticking out so much.
Post #987521 1st Apr 2023 7:28am
ickle
The wheel adds insult to injury by bashing into the only straight panel left on the car!
Just goes to show no matter how sensible you are / drive sh17 happens....
Post #987551 1st Apr 2023 2:03pm
Procta
I have seen something very similar 23 years ago, when we were coming back from holiday, We were approaching a large a rounder about, ready to go right, and a car towing a caravan on the other side of the road, was turning onto the main road, we were on. They had just moved off and then the wheel from the caravan just went its on way, It bounced off the kerb and went a good few feet in the air. Lucky it never hit a car, at all. They sharp stopped there and then to sort it out. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #987833 3rd Apr 2023 8:39pm
