Home > Maintenance & Modifications > Mercedes c class air vent mod. |
cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 52 |
Looks great do you have the part number for the vents and do they just push in after the filing many thanks
27th Mar 2023 5:49am |
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 |
Sorry for the delay.
Images attached. I think I probably slightly over filed them - and I ended up with a slight gap at the top where the silver rim meets the dash - there are fins inside the dash I cut back but in the next one I’ll try to keep these. I had a cut down the backs as well - but what I did notice was because they are longer Than the standard ones you seems to get a better seal and therefore improved air flow. On the next one I’m going to see how much I can keep. Ed. Click image to enlarge Click image to enlarge |
27th Mar 2023 8:21pm |
