![]() | Home > Wheels & Tyres > CAN YOU MIX 4X4 TYRE PATTERNS? |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3393 ![]() ![]() |
Legally, yes (as long as they're not a mix of cross ply and radial).
However, the G90s can be a bit skittish in the wet so depending on what the rear tyres are, you might get some unpredictable handling. ![]() |
Just having a shufty in your gallery, I wouldn't be mixing those as I'm sure the XTRA grip pattern are cross ply and the G90s are Radial. you'll be facing into the oncoming traffic before you know it!!
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
I wouldn't fit G90's let alone mix them
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 530 ![]() ![]() ![]() |
Crossplys, I had them on my first 110, back in 1996. I had them fitted for about a week, absolutely lethal things! I replaced them with a set of Bfg Track Edge. They were fantastic.
Jonathan111 Member Since: 22 Jan 2015 Location: London Posts: 67 ![]() ![]() |
Thanks Mark, all - looks like I'm saddled with the G90s so what's best to put on the back axle (definitely not the current Deestone Extra Tractions - lethal and noisy - useful thread here https://www.defender2.net/forum/post339275.html) - maybe the best thing is to put another couple of G90s and at least its safe......I'll be doing mostly tarmac driving, and mostly in dry southern Europe
Thanks camelman - this explains why I did a fishtail/aquaplane on a wet road three years ago - iffy crossplies on the back (Deestone Extra Traction - thread on them here -https://www.defender2.net/forum/post339275.html) and some very elderly Avon Rangemaster radials on the front. I should have learned my lesson then, have certainly now - showed the wife your YouTube clip, I'm off to ATS this morning.....question is : what do I put on the back axle - another couple of G90s? That's the advice I've had so far.... |
- ah thanks! I'll remember for the next time....! |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1462 ![]() ![]() ![]() |
The G90 is a very extreme offroad tyre, chosen by the British military for it's strength/ durability. It is not by any means a tyre that would be chosen for its capabilities on road regarding: wet weather, ice, vehicle handling or ride quality. A 'normal' MT or AT pattern is a much better all round compromise, if you don't live offroad 90% or need a very tough tyre. With 2 G90s already fitted, you have 2 options, 1) Fit another 2 on the back and live with their limitations. 2) Change all 4 to something more suitable for travelling across Europe, or general mixed use. Don't forget the spare tyre, if it's a crossply and ever needed to be used, it would be lethal to fit it with 3 radials. |
I'd be cutting my losses and selling the G90s on one of the military pages and sticking a decent set of ATs on if you're doing a higher number of miles.
hi, thanks for this - very helpful - I think I'm stuck with my G90s, so will just live with their limitations, and may even try and take advantage of them, should do more offroad. As a matter of interest, are there any tyres you'd recommend for general use that are not in the (out of my budget) BFG category? I'm being offered some Michelin O/R/XZLs - would they be a better bet than the G90s?
The 7.50/16 size has limited availability, it's an old obsolete size.
Michelin is one of the few manufacturers that still make that size. https://www.michelin.co.uk/auto/browse-tyr...0/16/112/S The modern equivalent is 235/85 R16, same diameter, a little wider, but really needs a 6.5" or 7" wide tubeless wheel. Falken and Toyo do AT tyres in 235/85 R16 from around £140 per tyre. I've no recommendation for the website below, have never used them, but do use them for a price guide. https://4x4tyres.co.uk/tyre-search-results...size/3495/ |
hi there, really appreciate your advice - it does seem that my wheels mean there are very limited options, looks like I'm going to have to go with the G90s for now and go carefully in the wet - I've been driving with ancient radials and wacky crossplys these last three years, so at least know how to do that....departure date is 2 weeks, so the wheels and tyres reset will have to wait....thanks all
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 104 ![]() ![]() |
Somewhere in the back of my mind, maybe lurking from a very long time ago, I recall a rule that said "radials to the rear". So if it is the case that you have cross ply on the rear and the G90's are radials then I think the tyres need swapping round.
Still not ideal but better than the other way round. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17680 ![]() ![]() ![]() |
The XZL is infinitely preferable to the G90 and is a very good tyre. |
