![]() | Home > Tdi > R380 cooler install |
Well done on sourcing the LR adapter, I think it is the right choice for the UK. There are not many moving parts in the adapter and if it were me I would strip it down and rebuild it so I knew it was done correctly before fitting. I do not trust anything on eBay that says recon/refurb'd/rare. I doubt the chineseium oil coolers have anything wrong with them and like you say they are probably all made in the same factory. If I was buying again I would buy a double pass cooler purely because there would be fewer connections to leak. There will be a difference in cost between the single and double pass coolers but it will not be too different. I actually like the idea of an LT230 cooler and pump to feed up to the roamer drive. If I were doing it (when I do it) I would feed up to the upper filler grub screw and extract from the drain bung in the extended sump. Might as well use what is already there. A filter, pump (switched thermostatically via the temperature sender) and cooler in-line and bob's your uncle.... It is a good idea for a modification ![]() |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
Heaps of choices regarding thermostats https://www.ebay.com.au/itm/172228406180?c...U5EALw_wcB
I'm going to fit one under the seat as per everyone else, one for the LT230 would also be a great idea. |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
Well, believe it or not I’ve just ordered a dual pass cooler from Aus! Their delivery estimate was 23rd April - the one from Poland was 20 May. I assume they were just going to walk over with it!
The LT230 is more complex. I’m not actually focussing on cooling the TBox itself, which I think has probably proven itself the world over and certainly in situations which would be massively more challenging than anything I’ll subject it to. My “perceived” issue is with the Roamerdrive. I say perceived because I don’t know with any certainty what caused my bearings to get so noisy, so quickly, but I’m assuming it’s heat. Roamerdrive themselves say that you need to be careful not to let it get too hot - but the temperature gauge they supply is intended for fitment in the LT230 sump - about as far away from the OD as it’s possible to be and still be in the same oil reservoir. So the thinking is to take oil from the sump and to plumb it in to the very back of the OD casing where the smallest bearing sits, but also the one with the most limited oil flow. Thermal cooling of the bearing would be a side benefit to simple lubrication. Heat stickers and the temp sensor would guide whether or not a cooler would be a benefit. I’ve seen pics of someone in Aus. who has done just that, but your ambient temperatures are quite a bit higher than ours - or at least mine, in the nth of Scotland. But if I get the oil flow sorted out then adding a cooler would be simple to do afterwards. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
