Home > Technical > 1989 Ninety fuel gauge & sender unit wiring
mini Anaconda
The fuel gauge in my Ninety has been a bit erratic the past few weeks and has now stopped working altogether. The sender unit has three wires going to it.
Slate grey wire on sender unit has 12 volts, low level light I think.
Black earth tested for continuity, ok.
Green/black trace when connected to test light (test light only glows) the gauge starts moving. When tested with a multimeter its only showing 7 volts, should it have 12 volts on this wire? BORG - Bucks & Oxon 4x4 Response Group
Post #986436 22nd Mar 2023 7:30pm
